The IE600 has a very natural timbre. Maybe you didnāt like the tonality. And the IE600ās bass is audiophile, not for bassheads. ![]()
Definitely needs more Bass for me. Also, I prefer the less sharp vocals on the UP. The IE 600 sounded slightly thin, sharp on some occations.
Not yet , I have a few incoming that might chalange it.
I never bought the top but from learning others impressions dont think that is a contender.
Has anyone compared the UP against Meteor?
I expect @MMag05 has at some point?
@VIVIDICI_111 kinda almost literally just did
I have a set of ISN EST50 coming in so thatās going to be an interesting comparison.
And a set of Oriolus Szalayi!
I have and currently own both. Donāt have notes directly comparing the two though and unfortunately theyāre both out on tour. What I can say for sure is though they graph similar theyāre drastically different sounding IEMs from the bass to the treble. If you have a specific questions Iād be happy to answer if Iām confident with my thought and not being able to directly A/B currently.
Well, I just want to know how different is the sound signature of Meteor when compared to UP.
Like I mentioned before, the UP checks almost all my requirements for a good IEM.
*Solid and Tight Bass
*Weighty Vocals that sound pretty Natural
*Treble thatās not harsh but does not sound dull
*Good amount of detail
*Above average Imaging and good soundstage depth
The only complain I have is that I like a wide soundstage and the UP falls slightly short in this aspect. On some rare occations, I feel like it could use a bit more air in the Treble region.
I recently tried a couple of IEMs at an event and some IEMs like Campfire Solaris Stellar Horizon, Vision Ears EXT⦠sounded better but they are way out of my budget so Iām hoping to find an alternate at a lower price.
Around the price of UP, I tried FH7, IE 600 & Advar and they all donāt sound as good as the UP to me. The FH7 does not seem like a big upgrade over the FD5 that I used to have. IE 600 has good soundstage width, air⦠but Bass is lacking and itās a bit sharp sounding sometimes for my tastes. Advar has good vocals but everything else falls short of the UP, itās DD does not seem to be as technically capable as the IE 600ās.
@VIVIDICI_111 I never tried EQ with the UP, not because Iām a purist but because I suck at it and since most EQ implementaion seemed to degrade the sound quality a bit but, I gave it a try after watching your review (6 dB Low Shelf at 100 Hz in UAPP) and itās pretty fun, definitely punches way harder than before. I actually think itās a bit too much for me and so reduced it to +3 dB but thanks for the reminder to use EQ.
hello,
i heard the xenns up on danās channel. It was love at first hear. Checking the price it is evident to me that I cannot afford it. Can you help me choose a similar iem in a budget bracket?
thank you.
Thatās literally my thing, friend. Just go to my upgrade matrix and itāll help.
Sir the problem of viewing the entire sheet is still persisting. THe sheet is missing scroll bars and cannot be slided or zoomed .
For me it works perfectly fine on the computer (after some loading time)
please advise how to
Your feedback would be helpful to help me see where I can make adjustments to viewing issues
Works fine for me on a MacBook pro but loading time is a tad slow and I keep getting this at the bottom right of the screenā¦I understand but it keeps popping up every time I zoom in or out ![]()
Using it from a windows computer and do not get this message.
All scroll bars are there and no issues apart from the slightly long loading time
