Hi! I’m interest in buying a Marantz CD6007 disk player.
I have some Ruark Audio mr1 mk2 (amplified speakers) already connected to a turntable, so I only have the optical or aux input to connect to the CD player. In this sense:
- How would you recommend connecting the Marantz CD6007 directly to the speakers? In this regard, can I directly connect the reader to the speakers, without the need for pre-amplification?
- I would also like to ask you if, from your experience, there is a loss of quality when optical cables are used instead of coaxial cables (on this particular setup, if applicable).
Thank you!
