I’m planning to do streaming and YouTube voiceovers on Xbox and I need a new headset. My budget is under £100 and these two headsets seemed to be the best.
I cannot buy a dedicated microphone due to my lack of access to a computer, what headset would you say is the best out of the mh630 and the arctis 3 and why? I do lean to a better mic however I prefer the looks of the arctis 3 as they come in white
Although I liked my arctis the pads are pretty shallow and I feel they can get a bit uncomfortable. The hyperx have better pads way more comfy and I personally think it’s the best balance of performance of most headphones if you’re looking at a lower budget.
Also, the hyper x have better mics. I would only choose the arctis if you were using pc because the software to customize. Without customizing the sound and everything they’re just okay. I didn’t like my arctis on the Xbox but liked them on the pc okay. If I could’ve gone back I’d have gone for hyperx. Maybe even the cloud stinger if you want something even cheaper.
In the end I chose the Arctis 3 and I’m quite happy with it, I’m using it on Xbox and honestly it’s great however there is a little echo and my friends can hear my game audio a little while I use a wired controller but I think this can be eliminated with an adapter/amplifier?
Hmmmmmmmm maybe. I got my gf a cloud alpha and she likes it more than my arctis 7 but it also gives echo that the arctis didn’t have. Sooooooo luck of the draw? lol.
