I love vocals, and I listen to a lot of Pop, Singer-Songwriter, Ambient, Mexicana, Jazz, and Country. I’m in the $50-$100 range (I can go higher, but obviously I’d rather not). Also I will be mainly using this on my iPhone with the 3.5mm dongle. I do have an AMP (THX AAA 789), but I usually use headphones at home.
HZ Heart mirror probably.
Do you own them?
No I dont. But judging by the reviews it seems to be a bright-neutral set, which works great for vocals.
Sounds very similar to the Tanchjim Oxygen that I have.
In that price range, you dont really have many great vocal iems.
(Moondrop SSR, could be another option, but I wont rec it since I dont think it is a safe rec due to the treble peak.)
I’m thinking about the Tin T2. Would you say that’s a good option?
It should work, but I think it might be a bit outdated now with stuff like the Heart mirror out there.
The reason why the T2 is so famous is that it was like the only iem at that price that wasnt V-shaped at the time of its release.
Yeah fair. I just couldn’t find the Heart on Amazon. Were do I buy it?
aliexpress. Everything is much more expensive on amazon and most stuff aint there.
For whatever it’s worth I prefer the blon 03 for vocals over the t2 any day. Timbre and tonality is much more spot on
yeah, vocals on the 03 are actually quite good. The bottleneck is the bloated bass, but that can be fixed with the mesh mod.
And im the only one that’s cool with the bloated bass lol. It’s fun
For a 100 bucks the Tin P1’s are darn close
wise and you’ve got the
with the 789 to drive them
They did mention that they will use it on their iphone + apple dongle the most, so thats why I cant rec the P1.
