MiniDSP 2x4 HD vs MiniDSP 2x4 Balanced?
What does the HD have to make it so much more expensive than the BAL?
HD has 4 outputs - I believe the unit can easily be programmed to make 2 of them preamp outputs, and 2 of them subwoofer preamps?
The BAL appears to have 4 outputs. Can you do the above on the BAL?
Can the outputs on the BAL be adapted to TRS or XLR at the powered monitors?
Why wouldn’t I run a Topping MX3, or Topping DX3 Pro instead? Just because they don’t have low pass filter etc for subwoofer?
Is there anything like the MiniDSP but with Bluetooth?
Thanks all
