Does the Minidsp SHD Studio have the same bass management capabilities as the Minidsp DDRC-88D with the 88BM option?
If not, what bass management capabilities does it have?
(This question definitely seems like it should be asked on the Minidsp forums instead, but I would like to avoid making an account there if possible. I wouldn’t object to a de-listing of this topic and eventual deletion.)
Thankyou for these links, honesty all I want to do is run a crossover between a sub (maybe 2) and speakers, no need for anything crazy so I’ll probably just yolo it. Weird that I can’t set a custom crossover between my speakers and sub(s) though.
Nvm, actually read the manual and I can set custom crossovers for speaker/sub integration. That’s all I needed, bailing on the DDRC-88D (just planning a 2.1/2.2 system). Thankyou!
