MMX300 G2 600 ohm OR DT880 600ohm
Hi there,
hope someone could help I’ve searched the forums to see if this has been asked before but couldn’t find it anywhere.
I’ve been looking at upgrading my gaming/music audio for quite some time now, and I’m planning on getting the JDS element 2 as my AMP/DAC as I don’t want to upgrade for while after that and If I decide in the future I want to try some power hungry headphones I won’t have to worry, But I’ve been trying to decide between the MMX300 600 ohm version or the DT 880 600 ohm I struggle to find reviews for the MMX300 600 ohms but the one that Z did was amazing but I’m not sure what version he reviewed the 32 ohms or the 600 ohms. Then I see alot of people recommending the DT880 for competitive gaming which I’m looking for mainly. The mic doesn’t bother me its not an issue not fussed if I buy a modmic or something but, which one is better a headphone MMX300 600ohms or the DT 880 600ohms. hope someone can help me really not sure which one to buy. Also I live in the UK the DT 880 600ohm is currently on sale at 153 pounds on Amazon and the MMX300 600ohm on Beyerdynamic Website is 230 pounds. Thank you (currently using the Sennheiser Game One) :slight_smile:
Dt880 600 ohm is great and that would be my pick, I think it’s just the superior choice. The element 2 would run it just fine
Would go with the 880 as well especially for the price difference
thank you think I will definitely buy with it being only 153 pounds right now :slight_smile:
