Yee I mean maybe my snobness ain’t helping me in this particular case. I just want technology to suck my dick in some ways. Guess I’ll just settle for a bag full of Lays
Not entirely sure what the big deal is with USB-B micro since it’s only going to be used for charging anyway. AFAIK it’s a myth that it breaks more easily. The only major difference is you don’t have to care which way you’re inserting the USB-C, and even this can be solved for micro-B with some symmetric magnetic adapters.
Honestly I’ve had more types c fail on me then micro b connectors, but type c is kinda necessary for higher speed connections like 3.2 gen 2 or thunderbolt. The micro b connector isn’t up for the task, but I would rather have a full size a port then c tbh
It doesn’t need to be fast since you would be using at as a USB dac, the interface speed wouldn’t matter. Also your limited by your price range if you want a fast dap, along with the usb c requirement
