Monitor controller to headphone
So stupied question ahead. If i use the out on a mackie bigknob passive and a 2 ts to trs adapter can i use 50 ohm headphones until i get a proper headphone?
Adapter like this https://www.amazon.com/TNP-3-5mm-Stereo-Breakout-Adapter/dp/B079JQQSCC?ref_=d6k_applink_bb_marketplace
Thank you
Unless the BigKnob is fed from a device that has a line level output that is also a headphone out (most computer motherboards, RME ADI-2-DAC FS, etc.), no.
Except for those above devices, you always need an amplifier of some sorts.
I guess the topping e30 is not on the list.
Thank you for the help.
