šŸ”¶ MoonDrop Variations
Hello, I’m fairly new to hifiguides in general. My previous iems are blon 01, blon 03, kz dq6, moondrop spaceship, and kz edx pro. Sources: as of now cx31993 and oem alc5686 4.4mm dongle. After trying some budget iems, I realized that there’s no significant upgrade to budget stuffs, I could try to go around 300 usd, but I prefer one time big time purchase. I mainly use earbuds(diy) because there’s something in the mids of the buds that I can’t get with my previous iems. I’ve been eying moondrop variations for my purchase. I’ve listed some reasons not to buy it. I’m hoping that you could help to test some tracks links if the reasons will affect my listening experience.
Reasons not to buy it:
Fit
Thin mids?
Mid bass lacking?
Can be shouty?
Male vocals sound shallow?
It has around the same size as kz dq6? It’s good if it is around the same size, dq6 have a good fit for me.
ps. I could probably get moondrop variations for around 432 USD brand new.
Test tracks/playlists(youtube):
Forgot to add, which is a better option
Straight to moondrop variations+current dongles or blessing 2 dusk+(fiio btr5 or qudelix 5k)?
I can’t speak to whether you should get the Variations vs. your current IEMs. All I can say is they are amazing to my ears - basically end game as I am already over and above diminishing returns.
Re: Variations vs. Blessing + dongles. They both sound the same.
The only differences are that Qudelix 5K has EQ and both 5K and BTR5 have better volume control vs. dongle.
Thanks for the response. Please share some playlist /songs that you mostly enjoy with variations so I can test it if will align with my preferences.
You’ll be happier with Variations + current dongles. It sounds hella great with my Sony NW-A55 and that’s the least powered DAP.
EDIT: Supposed to reply to @Maki_Zenin , my bad!
Thanks for the reply. Now I’ve got less reasons not to buy it haha. It’s size is the only challenger for now. But I wish that moondrop would update the variations like moondrop chu update from spaceship.
Tips will definitely help with the fitting. My ears aren’t that big but it fits nicely with mine and I was able to wear it at ease for more than 3 hours. I’m still using the spinfits CP145 (M) today and is still comfortable!
I don’t think a good dongle vs BTR5/Qudelix will make a significant sonic difference either way. The main benefit of these is the Bluetooth option, and the PEQ on the Qudelix 5K.
I have both IEMs and both are great. Personally, I find the Dusk a better all-round tuning than the Variations. The Variations is very good, but it’s a more opinionated tuning, the Dusk is safer with more stuff. And the Variations is also $200 more, it’s not $200 better, IMO. So I’d say just get the Dusk. But if you do get the Variations, it’s also very good.
Thanks, my only issue with dusk is I don’t have the payment option to buy it directly from shenzenaudio but if someone resells their unit it might be a good option. For the Q5K I’m also thinking of the portability + peq so if ever I want to change the sound of the dusk it will be easy.
Anyone can share a photo side of moondrop variations/blessing 2 dusk with the kz dq6(I’ve seen a post that says that the size of variations/b2d is around the size of kz dq6) so I’ll have an idea for the fitting and size.
+1 for Q5K. I got it for the PEQ and am very happy the ability to EQ on the go
China ohhh China😔
Could you compare variations vs yanyin cannon?
The variations are more of an open back……….
Joking aside, I’m pretty pissed that this is now the 5th ChFi earphone with major quality defects!
I’ve made up my mind that I’ll never pay more than $100 for chinese crap again, so it won’t hurt my wallet that much
They need to learn from Faaeal(buds in general), their glue is strong af🤣
That adds up to reasons not to buy md variations
I got weak and pressed the order button :see_no_evil:
No regrets. You’ll like them and congrats!
