Fucking t1. The only hope for him are the cheap Logitech he wears cause he would be burning through cash . The abuse he puts those poor cans through saddens me
Empyreans where the most comfy
Mr Speakers Ether Flow 1.1
my 1990s with Dekoni Elite Velours pads are now phenomenal though still a bit clampy on my huge head
love the Focal Elegias pads on my skin ![]()
bit worn out HD 600 was top
58x for my wifes small head is ok
not to forget the Koss Porta Pros with Yaxi pads is hard to beat
My Nighthawk Carbon are the most comfortable headphones I have ever used. Could wear them for a whole day if I really wanted to. The DT 770 Pro is pretty comfortable too. I have not tried the Takstar Pro 82/Cooler Master MH751 that Zeos says are the most comfortable headphones for him.
yes it is!
and the similar build Kinston Hyper X Cloud II with pleather pads is really good though gets hot over longer periods
Thatâs the thing I have found with leather and leather like materials. Seems to get hot. I use the Ultra Seude pads on my Nighthawk for this reason. Much more comfortable, plus it dials the treble back ever so slightly and brings the bass up nicely.
Thereâs a joke in there about a wife, and a little head.
I find the Dekoni Blue comfortable to wear all day. Their pads really are a delight.
(generally) are all the Fostex mods comfortable?
If they donât have the stock pads then yes for the most part
So Argons and T60s would be very comfortable then?
The argons if you get the upgraded pads are, and I think the t60 is as well
I think the only thing to be aware of with the T50/60 stock and Deckoni pads is the rectangular interior of the pad, isnât the biggest. I find them comfortable, but if my ear were much larger it might be a different story.
IMO the Ether CX are the most comfortable headphones I own, they can be worn for hours with no issues or no clamping force. You forget you are wearing a headphone.
they also look fucking awesome
They do feel great imo, build is excellent
My vote is for the AK7??'s. They are incredibly light, the pads are good and their relatively breathable material wise.
I use my 7XXâs fairly regularly for long gaming sessions.
Eye of the beholder situation, out of the list, probably the x2 but comfort really shouldnât the the primary concern, the other headphones are comfortable âenoughâ
Absolutely harrowing, thank you
