I’m yet again searching for a pair of budget iems for around $60 , I currently have blon bl05s but now I’m searching for the most amount of midbass in that price range , I don’t mind if it leaks a bit into the mids or if the mids are recessed , I just want :
Most midbass slam , not too bloated and well textured bass ( a little bit of leak into the mids is fine )
Good treble extension and energy ( I don’t mind if they are a bit shouty )
If possible , some sound stage
If there are some recommendations that meet my requirements and exceed my price range ($100+) feel free to mention it , any help would be greatly appreciated and thanks in advance !
Just one final question , do I use them with the original tips that came in the box , or are there other tips to further enhance the bass or better overall for this set ?
Otherwise the Final Type E tip is my favorite one for a warmer tonality.
The CAP20 is my best tip for a more balanced tonality.
(and if you want a brighter tonality, the Radius Deep Mount is my favorite.)
So the Elecom EHP-CAP20 are the ones that have the most midbass ?
Also , can I use them with a btr5 balanced , won’t it ruin the sound signature and lessen the bass ?
And should I use a copper cable or a silver one or just use the stock cable ?
Thank you for your help it is much appreciated !
Tips only affect the treble to me, but lowering the treble or smoothening it will increase your perception of the bass. So if that’s what you want the type e tips is better.
All this does is give you more power. It’s only better, won’t affect the tonality.
Snake oil. Pick whatever cable you like from the aesthetics, if you are worried about the quality, then you can pick an A cable from my cable list
