Which one of these would work best as purely just a center channel? Dollar to performance wise.
From Z’s review while the OoO had a great sound, it wasn’t room filling good, and the same could be said of the RB42C but the 42C was noticeably better at it. Do you just need a center channel? or are you also looking to get a larger set up?
I already have a pair of Elac Debut 6.2. It’s in a small-medium sized room. Just wanted the best bang for buck for a center. Since they have the same tweeter I was unsure.
What about an elac center channel? You might be able to find a good deal used, Debut 2.0 C5.2 should be something to look into
