Is there a way to make windows 10 output to more than one USB at the same time?
You could most likely do this with ASIO but it might be a bit clunky for USB devices. You could get a toslink or spdif splitter if you wanted to do this a bit easier
Yeah I have a few, just was always a concern in the back of my mind that it was affecting quality by splitting the digital signal.
Not really no, it will affect the signal but typically not to a noticable amount
Ahhh alright. I’ll probably go back to that route then
There is an open source program called Audio Router, but I’ve never tried it. The only one I’ve used is Voicemeter which only works for two devices and is terrible.
