Need a power adapter for dac?
Hello, im new and i need your help.Im about to buy a topping d10 dac from drop.com but i don’t know if i need a power adapter for dac (im in turkey) are they sending with adapter or should i buy seperately
The topping d10 only needs to be plugged in via USB to get it’s power, you should be just fine. It should come with a USB cable
Thanks,and what would you suggest for amp,i have hd58x
It mostly works well with most amps, the jds atom, magni heresy / magni 3+, liquid spark, etc
What’s the best for your opinion in this price range?I’m sorry but i don’t know the factors im new
I think schiit has an eu store, so the magni heresy would most likely be my pick here
