Need a recommendation on finding a" fun and versatile" headphone
So i had some problems with hd58x. It cant be shipped to Thailand.
With that said, I need another headphone with the same price range(0-150$) that is good for any kind of music genre and also for single player rpg games
I considered hd598
You can maybe give a Koss KSC75 or Porta Pro a go. Very cheap for good sound, ~20-50 USD but idk about your region. They do not pick up fine detail as well as more expensive headphones, but they have great sound signatures. Only real issue is they are a bit fragile in construction and on-ear. Sound quality is definitely inferior to something in the 100-150 USD range, but only by a lit bit. It’s a value proporsition that will make you wonder if a small improvement in sound is really worth $100 more much in the way a 58X makes the much more expensive 660S a bit questionable for the budget-minded headphone enthusiast.
Only other open-backs of the price range I have experience with are the Audio Technica ATH-AD900x. They are tuned brighter than the HD 598 and don’t really do bad with any genre of music. Though bass is on the light side, there’s good clarity there. They were my daily drivers for over 3 years, and I was perfectly happy till the upgrade bug bit me recently. I wouldn’t say these are the best of their price range, but I don’t have issue in recommending them either.
This is a wild, baseless assumption, but I think you can definitely enjoy the HD598 provided you’ll like the sound signature. It’s a good headphone at a good price as far as I can tell. It’s just that the 58X some would consider to be a good headphone at a great price. The 6XX a great headphone at an even greater price.
What is it plugging into?
