Need Balanced Cables
anyone know where i can get a good set of balanced cables for the THX AAA 789?
I have used periapt cables before and was pleased with the results.
https://periaptcables.com/
All my balanced cables have been periapt, they are really good quality that’s affordable as well
If you’re asking about cbalanced interconnects, then any well made cable will work well. I have had good experiences with “World’s Best Cables” on Amazon. They use a lot of Audiophile BS in their marketing, but the cables are made with quality parts (Canare, Neutrik), and are priced well.
Yeah whatever balanced cable can go from the THX to a balanced DAC.
Short runs like box stacked on top of box? Use a short XLR cable interconnects. You will need 2 of these.
Monoprice Premier Series XLR Male to XLR Female - 1.5ft - Black - Gold Plated | 16AWG Copper Wire Conductors [Microphone & Interconnect] https://www.amazon.com/dp/B003L18XKE/ref=cm_sw_r_cp_api_i_KtDlDbXHHAT3G
Want to spend more on cables, then there is Mogami like the ones I use for my microphone.
Mogami GOLD STUDIO-03 XLR Microphone Cable, XLR-Female to XLR-Male, 3-Pin, Gold Contacts, Straight Connectors, 3 Foot https://www.amazon.com/dp/B0002E1P2G/ref=cm_sw_r_cp_api_i_ftDlDbE3Z6MWC
