I have a pair of Vanatoo T1s (they’re powered speakers) that I used to run off my laptop via USB without a problem. But recently I acquired an Asgard 3/4490, which I now use as a preamp for the Vanatoos. So MacBook via USB to the DAC built into the Asgard 3…and then RCA line out to the aux input on the back of the left Vanatoo. It’s not the best way to connect the Vanatoos given the way they work, as they literally reconvert the analogue signal coming out of the Schiit BACK into digital, but I really appreciate the reduction in clutter that comes from being able to connect the Vanatoos serially to the A3, and my ability to control the speaker volume using the big Asgard knob.
BUT: there’s a quiet humming that’s audible whenever there is no headphone plugged into the A3, which is what switches the unit to speaker pre-amp mode. That hum is NOT affected by the volume knob and is present when the volume is turned completely down. It goes away as soon as I plug in a headphone.
So, what to do?
