Need help finding a rugged phone case for the Galaxy A70
the A70 has no water resistance at all and I live in the wettest place in Canada, so I need to find a waterproof case before I click order. I’m also a clutz, so need it to be drop-proof as well.
there are a number of cases that come up for the A70 saying they’re rugged…but no details on being water resistant, let alone proof…or that they will survive a drop or tumble down the stairs like the Otterbox Defender will protect from.
help!
Something like this probably?
yes…but that one isn’t waterproof, as the reviews share. it also muffles sound and isolates so that NFC can’t be used.
same story for the case by Feitenn as well. :stuck_out_tongue:
Good thing is that you can always search a perfect case first, then a it’s easier to fit a correct phone to that. :wink:
a weird thing…the A50 has an Otterbox Defender case, but the A70 does not. granted…Otterbox is not waterproof. but how odd!
