I am trying to figure out between Jamo C 95 II and KEF LS50 for my front speakers for a 14’ by 16’ living room with an 8’ (diagonal ) opening at one of the corners where the left side speaker would go to a 10’ by 10’ room. My max budget is around $800 USD and I am open to suggestions.
jamo’s will be cheaper. what is your amp you are using? the kef’s can be picky and need a lot of juice. if you are going 2.0, the jamo’s will dig lower as well.
the jamo’s will sound “smoother”, while the kefs will be a chunk more detailed. some find the kef sound to bright, some find jamo’s to laid back.
jamo = more relaxed chill sound
kef = detailed tight sound.
I am going to buy a receiver I am looking into Danon or Yamaha. So its going to be somewhere between 90 and 100 Watts per channel. I am looking to eventually expend to a full 5.2 but as for now its going to be a 2.0. I am trying to fill the room correctly for a movie/TV and music 60/40 % split
have you thought of looking for a good deal on used speakers so you can get better room filling sound?
If i get KEF it will be used for around 750 pair
okay…so it’s not an if / or situation…you’re open to buying used gear if there is value in it.
yes, I am just trying to stay within a certain budget. I do like z’s review of the two speakers or should I say the smaller brother of the Jamo and the KEf speakers that is why i put those two down in my question and price-wise they seem in my max range but I do want quality for my front end setup.
well, the LS50 have a good chance of being enough…but they’re not really meant to fill a large space. they’re not as anemic as the LSX are…but hey, you gain experience and $750 is a darn good price!
do you have a sub? having one will really help with filling your space with sound.
I dont have a sub yet and as for the LS50s I was thinking the passive once not the active speaker
yes, the LS50. they are passive. the smaller LSX are powered, but meant for nearfield.
ok, if you have any other speaker ideas for the room size I am open for other people’s opinions
Triangle borea br03’s have nice bass for a two channel and are front ported for easy placement… imo they have really good imaging so they should be nice for movies… I use mine for music and they’re pretty nice and a little forward from neutral
They’ll also fill your room np and actually are nicer when the volume is turned up a bit
Also consider elac debut reference and klipsch rp600m
thank you very much for the information. I will take all in consideration. I am not sure tho that triangles are in my price range unless I get used
Np… the br03’s are $750 in Canada… could be more for you though
There is the powered and wireless versio also on LS50. Bonkers more $ than normal ones.
Speaking of passive LS50, there was some guy selling 3 units, with 240$ each on local sale site.
They where sold in few hours after the post. Super cheap…
That is super cheap. I wonder if anyone else would sell them as cheap.
