I want to play my records through 3 pairs of speakers at the same, I have one pair by the TV & decks (Dayton Audio T65 - 6 ohms), also 2 pairs of polk atriums outside (8 ohms)
Would be great if I could get the TV playing sound through the T65s when needed but not vital
My budget is $300, do I need an amp & a speaker selector box?
If so I would love some recommendations and ideas for amp specs I’d need
Would it be more cost effective to get some kind of 2 in 1 unit if they exist?
With two pairs, you could get away with hooking both up to one amp and running output A and B together.
For three sets of speakers, I’d say multi-channel amplifier (from the home-cinema area?, or something like this)
Maybe something like 6-channel amplifier would do the trick ?
What outputs does the Rane mixer and Pioneer TV have or what outputs can be used?
Then those available outputs → need to be connected to a suitable 6 channel amplifier that support those with connections. When the needed connections are known comes the budget. Is there something available or is there not. Prices change when properties change.
