Need help setting up SHP9500 with what I have on hand
so in my possession I have
  • MH752 with the little DAC
  • SHP9500
  • Astro Mixamp Gen 1
My motherboard does not have an optical audio port so I cannot use the Astro Mixamp presets or dolby etc
My current setup is, whichever headphone I am using at the time, I plug into the MH752 DAC thing
should I be plugging something into the Astro Mixamp or no?
I was looking at the Syba Sonic DAC’s (the silver one and the newer black one) but am not sure either is needed to drive either headphone
newer black syba sonic
older white/silver syba sonic
my usage varies from serious gamer to casual gamer to media enjoyer.
any help appreciated
ty
you could probably get a cheap hdmi audio extractor and it would most likely have an optical out so you could use the mixamp.
