Owner of an M300 DAC.
Using Windows 10, SMSL XMOS Driver 4.67 and Fubar2000 v.1.5. Connected via USB 3 port and SMSL-supplied cable.
PROBLEM: I cannot get the DAC to recognize and display the bitrate of the file being played.
I am using a 44.1K MP3 and a 192K FLAC file for sources. Fubar indicates the correct file bitrates The M300 DAC only displays the Windows > Sounds > Device Properties > Additional Device Properties > Advanced > Default setting. I can manually change that via Windows settings to any bitrate desired.
Is there a magic configuration setting that will pass the bitrate Fubar sees to the M300 and change the display? A little help, please.
