Does anyone have a clue what tip size the TIN T2 foam stock tips are?
Haven’t tried others, but the 4.9mm Dekoni Bulletz fit on there.
These fit great.
4.9 MM replacements work if that helps.
You can buy the blue tips on the Linsoul website, comes with 3 pairs and a case for like 10 bucks I think
