Hello,
So I am trying to run a pair of Mission 760i Bookshelf Speakers (6 Ohms, 75 W). I need to get a Power Amp that can power the speakers that will have audio signals from a EVGA NUAudio Sound Card with the AKM AK4493 DAC Chip (32bit/384Khz) via RCA.
Mission 760i Speakers Stats:
- Enclosure Type: 2 way bass reflex
- Drivers: 1 x 130mm bass/midrange | 1 x 19mm dome tweeter
- Frequency response: 70Hz to 20kHz ±2.5dB
- Nominal Impedance: 6 Ohms
- Sensitivity: 89dB
- Recommended amplifier: 25 to 75 watts
I have a few requirements/preferences for a power amp. It must have RCA outs or a sub out as I will get a powered subwoofer for a 2.1 system. I also prefer Class AB amplifiers over Class D. I am open to used options. I don’t need a volume knob as I will be controlling audio levels through my PC. I also don’t want to spend over $150 (preferably less since any savings on the power amp can be spent on getting a better a sub). Currently, I have had a few options.
1 - Parasound zAmp v3 for ~$120 [45W @ 8 Ohms]
Things I like:
- Small Form Factor for a desk
- Very good measurements/Clean sound
Things I don’t like:
- Weaker power (though I doubt it will be an issue)
2 - Onkyo M-282 for ~$75 [100W @ 8 Ohms]
Things I like:
- Plenty of power
- Cheaper
- Measures slightly worse than the zAmp v3
- Big for a desk setup
Does anyone have any suggestions for which of the two might be better? Does anyone know of other speaker amps at this price range that would fulfill my needs?
Thank you!
EDIT: Fixed Formatting, Reworded
