Since the relief bill money is coming soon I’m planning on spending $500 ish to upgrade my gears. I think my amp/dac is the weak link but I don’t know if upgrading them is a good idea.
I love all my headphones but I don’t mind getting new ones! I’ve been eyeing the Elex but not sure if my fulla 2 can drive them well.
I’d really appreciate any input and will reply as often as I can.
I would look towards an improved dac and amp setup.
The Fulla 2 is pretty light for your Sundara and will continue to limit the range of headphones you could get.
If you’re a Schiithead, you could do a Modius/Asgard 3 stack.
Sell the Fulla 2 or move it to another role in your life.
You’ll then have a strong SE performer that should be fairly future-proof for future needs, opening up more possibilities.
If you wanted to save $100, I’d recommend buying the Modi 3+ separate DAC rather than the internal. Unless space factors dictate, I avoid the all-in-one, especially when there is no price premium.
The Modius is a better unit overall with the same form-factor as Asgard 3.
It is a balanced DAC with XLR connections (not going to be handy with A3) but gives future flexibility and connection options (even to separate amps).
Were it me, it’s $100 well-spent on the Modius vs. Modi 3+
Which is why there’s one on a FedEx truck right now, so so very near arrival.
