What speaker would you suggest?
I will be using these on a desk setup as computer speakers.
Thanks!
Thanks!
I like the RB42 because it saves so much space.
Neumi CS5 X 2 =
I have a pair of Micca RB 42’s that I use in near field on my desk. I <3 them. They look nice, sound great, and are smol so I can have space for other stuff. I will say if you desire something with some top end see treble the RB 42 are not for you.
I started out on my desktop setup with Neumi BS5’s and I loved them. I have not listened to the RB42’s, so I cannot compare, but I certainly had great success with the BS5. More to @Flaculence point, the CS5 would be taller but would have basically the same footprint on the desk as the BS5, and you get an extra driver on each side! I can’t help but think this is a good thing…
You save desk space with the neumi CS5 by going vertical. Bit skinny about same depth as the BS5 . I likem needs power but nearfield on a desk amp theyre fine. how much amp do you really need for the desk? Ofcourse more than needed.
