Thank you very much for that detailed answer!
Ive been reading a lot about hifi-man headphones. I guess, in that price category, they can’t compete with the dt 1990 then?
The 1990 is one of the best in the 450-500 range new. It’s just solid all around if you aren’t too treble sensitive
Okay I thik I will try to scout for a Dt 1990 then,
Another question (sorry for spamming): Im planning on buying a DAC. I first decided for the Khadas Tone Board but after some reading I’m thinking about purchasing the Topping D10, mainly because it comes with a box etc.
Are there significant differences between these two DACs? Do you maybe own them?
I have heard the d10, but never have heard the tone board, but people often praise it, so you might have to look for a comparison
May i ask, what your opinion on the d10 is? Or if you know another one thats maybe better in the 100$-150$ range? You seem to have great knowledge, thats why I am replying to you so much…sry
Np
The topping is just a great value. It measures well, is simple and workes easily, and sounds great. Dacs don’t make that big of a difference compared to other components like amps, and more importantly the headphones, iems, or speakers. I think you need to pass the $200 range for a dac only to really notice a difference. As long as you get something clean, which the d10 is, there really isn’t any need to spend more in this price range
The d10 could honestly be a endgame DAC, it’s that good. The only reason you would ever need something more expensive would be if you went balanced or needed different or more inputs/outputs.
You can rest easy knowing that the d10 is really good for the price and is built exccelent as well.
Thank you for all the answers! I’ll buy the d10 an try to catch a dt 1990.
This thread was really helpful!
Sorry if I’m hijacking this thread again. I just have one more question for you. I have a really good offer for a DT1990.
What, in your opinion, brings the most progess in a headphone set up. The headphone itself or a dac+ amp.
Im thinking about returning the DAC+AMP and upgrade these later on.
The headphones’s themselves for sure. The headphones are almost always going to make the bigger improvement
Thank you, thats was the last hint for me. You’ve all helped me a lot!
