Ddhifi. I own one. Built like a tank!!
https://www.ddhifi.com/productinfo/737346.html
If you have a bigger budget, something like qudelix 5k
can you sort / order these from best to least in relation to which would do orchestral / instrumental / classical music the best?
you knowā¦good, gooder, best, bestest?
They were just a suggestion list for the op to look at/consider not my personal experience list
Theres no bestest better ever in this hobby. Itās about preferences and libraries. Everyone is trying to find his mojo
indeed, but the public consciousness often finds things that the can mostly agree upon, hence products get reputations⦠like the HD600 being good for orchestral / instrumental / classical music and especially so on a OTL tube amp.
ā¦or, even as contentious ad it is, how the harmon frequency response is gaining momentum as a performance benchmark.
I was looking to see whether any of the mentioned IEMs have shown this to be true of them.
I will be buying the mele. What are some nice things to get the best out of them.
I might skip the Aria. Mine just didnāt hold up, the connectors were loose at 2 months and shorting before 4, and they didnāt leave my desk. I donāt have a good impression of recent Moondrop QC and manufacturing. The cable connectors were the common issue on the Aria, and it seems like they still havenāt fixed it, and the DOA reports seemed to go up for months. Also the stock cable sucks, so it is an $80 IEM that needs a cable upgrade.
Mele is a 100% agree
While I am hearing great things about that Tin T3+, and the KZ ZEX Pro, have either made it past the reviewers yet, and into the hands of normal people just listening to music? I think the T3+ is a yes, but the ZEX Pro is a no at this point. OG ZEX got more hype than it deserved, but only because of the under $25 thing.
Etymotic ER2XR is recommended a bunch. I canāt stand the Etymotic fit, but to each their own.
I donāt own any of these IEMs but Aria has been compared to Oxygen a lot and Oxygen is great for orchestral, classical music.
Iām waiting for my ZEX Pro
quite the price difference between the Oxygen and Aria, almost 4x the cost.
True. What I meant to say is that out of the three I would pick the Aria because it can give you an idea of this tuning for $80.
If you can add 30$ more. You can get T-Force Yuan Li or TRI starsea with a type-c Apple dongle.
If below 100$ is the only option. Then T3+, Aria, Legacy 2, Mele are all great sets IMO.
I always forget about that one. I almost bought the Legacy 3 around the time I got the Starfield. It sort of fell off the radar when the Starfield and Aria took that around $100 spotlight. Thieaudio really moved into their own place with Clairvoyance and Oracle, in more upscale price brackets.
