I JUST came from that vid
I have mostly already set on the zen can/dac combo + dt880 600.
I like the way they look, I know they work for the 600 ohm version (meaning I donāt have to sift through a hundred other reviews XD) and I know I can get them. Having to make the headphones balanced would suck, but in this case I want to modify the cables anyway to avoid the issues I had with my last pair, so thatās a non issue.
Stumbled onto the video you mentioned and I figured, I can get a tube pre-amp for about the price I save from getting B-ware outlet 880s (should still be fine right?). So in that scenario, it wouldnāt even cost me anything since I would have spent the difference on getting new pairs as opposed to the outlet version. I was just hesitant in that 40 ish euro for next to no advantage is still 40 euros wasted that I could have spent on better cables.
That said, I have no idea how much of a difference that makes, seems to be pretty open ended with even 100 euro cables. Blows my mind. Given the zen dac already has the bass boost as you mentioned, and if cheap tubes arenāt worth it, maybe that would be a better choice?
Or use the savings to cover for desoni pads, seems those would provide much more of a change.
good point
