Newbie here, looking to invest in a dac, amp, and headphones. I have been researching, watching reviews, and reading forums for a couple months now, and I feel like I need a little assistance finding the right direction to begin. My goal is to get a good beginner setup that will allow for upgrading components later down the road, if I want to take this further (which I expect will happen). I don’t have a set budget, but I don’t want to break the bank either, especially as a beginner entering the hobby. My main intentions are to listen to music. I will most likely play games with them as well but am entirely focused on music.
I like most any kind of music. I tend to focus on rock/punk/metal centric bands but will absolutely go for other genres on any given day. I’ve always considered myself someone who likes a lot of bass, but I’m not entirely sure if that’s truly the case since I haven’t actually used a set of quality headphones that does bass well. I think having a balance of everything is a good place for me to start. Correct me if I’m wrong.
Starting with a dac, definitely don’t need anything crazy. I plan to be mostly on my computer so usb connection is necessary and I would really like an optical in for experimenting and flexibility in the future. I’ve noticed a couple new dacs out on the market recently, specifically the Topping E30 and the SMSL Sanskrit 10th MkII. I’m curious of peoples’ thoughts on those dacs as they seem like fairly solid dacs for what I’m looking for and are fairly cheap. Certainly, I am open to other suggests as well, but dacs seem like one area that it doesn’t make a huge difference as long as you have one, unless you go really high end.
Amps are where I start to not really know the direction I should go. I feel like I should be looking at amps around the same price range as the dac to start and there are plenty of options, but I have no idea what would be a good fit for me. I’ve seen a lot of mixed thoughts on Schiit’s lineup but the new Magni3+ and Heresy don’t seem terrible. I’m curious how they compare to the Liquid Spark and JDS Atom that have been widely recommended. I just don’t know if I want to look for a warm/fun amp or something a bit cleaner (might not be using the correct terms), and I’ve also read the headphones paired with the amp make a difference as well.
So, in terms of headphones, my only thought is that I really want to try a pair of open back planar headphones. I was initially looking at the Hifiman HE4xx since they seem to be universally liked based on the value they provide, but I have been really liking what people have said about the Hifiman Sundaras, especially since their revision to the earpads. Are the Sundaras a solid choice for a beginner, and what would be a good amp pairing for them? Again, I’m totally open to all suggestions anyone might have. I probably know the least about headphones, there are sooo many of them out in the market.
Initially, I was thinking I wanted the cleanest sounding setup possible, but the more I thought about it, the more I’ve questioned that position. Now I’ve been thinking I should go for something fun to gain experience with and then worry about other stuff later. At this point I’m kinda leaning toward the Liquid Spark, but again, what do I know? Haha. Do the Sundaras and the Spark pair well together? Probably overthinking things way too much which is why I’m looking for some direction to help put my mind at ease.
Sorry for the long post, I wanted to get all my thoughts out there and give a good idea of what I’m looking for and what I’ve been thinking. It might be a bit scattered and might not make the most sense, I am still learning. That being said, if there are any guides/resources that are good to use, please send them my way. Thank you in advance for any input and feedback you might have.
As a side note, I am a little worried about the QC issues Hifiman seems to have. Would any issue in a pair of headphones be easily detectable? My worry being that I wouldn’t know if something was wrong and just assume the headphones are suppose to be that way.
