Greetings,
Total newbie question - is there any downside / issues with using a 3.5 to RCA cable / converter?
Minor context - I’m considering tipping toe in this side of higher end audio, tho I am largely a PC gamer. As such, I have been considering a Sennheiser GSX 1000 as a DAC and adding in a separate AMP just to experiment. I know if I got like a JDS Atom, I could pipe the 3.5 off the GSX into the Atom, but if I got a fancier amp like THX 789, of the JDS EL Amp that has RCA inputs, I was curious if there would be an issue or degredation going from the 3.5mm to RCA inputs on a seperate AMP.
Thanks for input!
I know for some headphones this isn’t strictly needed and I could use the GSX as a DAC / AMP combo, but I wanted to keep options open.
