I’ve been using my D10 for quite a while now and am considering upgrading sometime soon.
How much more do I have to spend to see a marginal jump in quality compared to the $90 Topping D10?
Considering pairing with the Atom or TXH amp by SMSL/Drop
The only real feature I would maybe consider is MQA. Worth it?
I have no need for additional inputs.
Ok, if you want to go that route then I would suggest you look for an enog 2 pro or a smsl su 8, but neither of those dacs have mqa support unfortunately
Yeah the su8 can output both at the same time, and if you wanted the thx you can use xlr and rca for the speaker. Personally I’m not the biggest fan of thx but it would work
literally an atom or magni heresy, just as good if not better imo. I think if you wanted to step up from that the asgard 3 or jds labs el amp ii (or el stack ii)
