Nice quality 4.4mm to 4.4mm cables/adapters?
been looking around for quality 4.4mm extensions or even just a female to female bridge/adapter and didn’t see anything better than openheart, wondering if anyone else has found some nicer ones before.
just a short extension is what I’m looking for around 6’'/15cm would be ideal
Null will build a custom one to your requirements…
hart audio now has a 4.4mm female setup that will work with their interconnect system AC44-7 : 4.4mm to 4-pin mini-XLR (For use with our modular interconnec – Hart Audio Cables
Nice to see Hart audio is coming out with new products I’ve had some issues with microphonics on their fabric cables though
Looks good I’ll have to shoot them a message
XINHS can probably do that for a lot cheaper.
I’ve had some mixed quality/experience with Xinhs unfortunately
What happened?
one of 3 modular IEM cables with iffy connections and all of them having off to way off indicators for plug orientation.
a custom headphone cable with the tackiest sleeving ever to the point of things sticking to it lol (minor gripe but not nearly as nice as I expected for a $70ish cable)
I had skedra at Viking weave make some interconnects and damn it was totally worth it.
tempting might have to message them too
