Noobish question - Line in VS aux in
What’s the difference between line in and Aux in?
And can I connect powered monitors to either one?
Line Level is the maximum amplitude of an analog signal.
“Line In” commonly labels a pair of RCAs while “Aux” is commonly a 3.5mm to quickly and temporary feed in “consumer devices” to sound installations (like a smartphone to a conference speaker sysem).
Electrically, they are the same.
So basicly, they are both a no for powered monitors,
Thanks :smile:
Line-In is more computer related term, usually audio going in the device.
Since you can have Line-Out also, audio coming out.
AUX is more the socket, in any audio related gear.
Can be IN or Out or just AUX. Depends of what it is used. :slight_smile:
You should connect monitors to Line Out.
Both are fine for powered monitors.
They sometimes have TRS-jacks that accept TS (unbalanced) and TRS (balanced).
You regularly use line-in as output audio for powered monitors?
Might have some issues from audio coming out. :wink:
Well, yes! :kissing_heart:
LoL.
We talked about Line-In. :wink:
I know i know I know.
