Guess I gotta spend 20 bucks ![]()
Do it! I ordered one already. It will take 4 weeks to get to me though
Same. The graph looks pleasant and itās basically the price of a set of spring tips.
Those add on ear hooks though. Iām hoping they sit ok without them.
Just ordered as well, but this time through aliexpress. No point in rushing as I have other stuff inc. Im guessing a week or two.
quarks were quite good for $10 on sale⦠tempting
Graph on Chu looks better than Quarks and if tech is better itās a home run
They also come with MD spring tips, which Iām curious to try. Iām still not convinced I can fit them, as everyone say they are smaller than average tips, but he will see.
Just wish I could grab a 20 dollar iem with spiral dots ++ ![]()
Iām pretty new to IEMs and all the tips I use are S size. They are the only ones that seems to stay in well enough. But it seems strange because I always see people saying they need bigger tips. And Iām a big dude, 193cm (6ā3"), so it seems odd I use small tips. Am I just shoving them too far in? Or I just got a small hole lol?
Every canal is different. As long as it seals and works for you, you gucci. Wearing small is great, since thereās always stock ![]()
for me the large Spring tips were between small-medium Spinfits⦠think there was one IEM I somewhat got them to work with
usually I use medium or large Spinfits
I thought i had small canals too, and then I discovered I could wear medium or even large tips.
It depends on the IEM and the shape of the tips as much as the shape/size of your ear canal.
First of all, you have to be able to recognize when you have a seal. It isnāt as easy or straightforward as one might think: again depending on the IEM and tips, it can take a lot of experimentation.
That is the blessing and the curse of the iem hobby: each new iem can be a source of discover and experimentation. But at the sale time it means that you have to engage in it to get the best out of your gear, especially as a beginner.
I feel blessed that I can seal everything but bullets easy. Took me a while to figure out not everyone is like this. Guess I dodged a bullet.
CP-100 spinfits are my Blon 03 favorite: they can reach far enough to get a good seal, but can slide off easily if you donāt scuff the stem.
The Spring tips are comfortable, they give way pretty easily in a springy sort of way. They are wide bore and short, and provide a good seal with my Starfields.
Spinfits donāt hold well enough on the bl-03 nozzle for me. They slide too far on it, and sometimes stay in my ear when I put the iems off.
I have to take some rigid and small bore stems so they stay in place and go deep enough in my canal ![]()
You can put an o-ring on the tip stem itself to make it tighter.
Here: Blon in ear monitors impressions thread | Page 328 | Headphone Reviews and Discussion - Head-Fi.org
@nymz any initial impressions for the IE600?
@nymz Have you heard the Kiwi Ears Orchestra? Seems itās a mid/vocal centric IEM
It has similar tuning as Dark Magician
I donāt have them yet. Might take a while, depending on customs. Everything has been really slow this month due to China crisis. Thatās also why I havent posted much and been focusing in other stuff. I have some nice goodies incoming, but I have no way to tell when they will land in my hands ![]()
Nope, I havent. I considered it when looking for a BA set. It was a battle between Kiwi, RSV and SA6.
RSV made more sense, but Kiwi is cheaper.
