I’ve got a few XINUS cables for my IEM’s but one suffers from a feed back/earth hum…apart from that it works fine, if I move my head around it comes and goes so I’m guessing it’s the MMCX connection/soldering reckon that makes sense?..got a wee soldering iron and feel confidant any advice
Add bluetack inside of the connector
It’s a good isolator and will prevent future misshapes
Otherwise I can recommend some gel flux for all solder jobs ^^
Too late I’m afraid just destroyed the MMCX connector trying to undo do it
New cable time
I don’t think that you get hum from a cable… i would rather wonder about the source. Certain IEMs can be so sensitive in my experience that it is very hard to find a clean source for them.
I agree but I’m running Tin P1’s which take loads of
to drive properly also a cable swop cured it
XD maybe the quickest solution to your problem
