hi guys, long time no see. I recently found my good ol’ Plantronics Audio 90 headset that i used for so many, MANY years as my only headphone, before getting into the “game”. I was curious how it would sound on my high end gear, and i have to say: i’m pleasantly surpised! Getting used to the sound didn’t take long, i guess there still was a matching compensation-profile for the frequency response stored somewhere in my brain. What do you call that - auditory memory? Anyway, i digress. The point is: i really like the soft pads this headset has, i like the sound, and it’s on-ear. I already own a couple of on-ear HPs like the KPH30is, B&W P5 / P5v2 / P3, Sennheiser 424 and i like all of them. Some things stick out for me for on-ears: 1.) they can be annoying to wear, 2.) they can be really pleasing to wear 3.) they are rather small and light, so more portable 4.) the connection between your ear and the HP driver seems more “intimate”, since the bass vibrations etc. are being transfered directly to you outer ears, compared to over-ears, where it’s more the air pressure from the driver that tickles… Long story short - i think on-ears really have something going for them that over-ears don’t. And that made me asking:
What are your recommendations for, or what do you rate the “best” ON-ear headphones available from a technical standpoint? As long as it’s not completely broken, you can even leave the frequency respone out of the equation, bc i always apply EQ…
Thx.
