Are they any good on ears aside the koss?
Another option would be Grado though there “issues”
- They are very open which gives them a certain kind of sound which is not everyone’s cup of tea, Personally i think they are very niche and only work certain songs (mostly live performance that are vocal focused)
- Stock pads are terrible so you have to spend another 10-15$ for the pads (it should still be under 100)
- Attached wire is very thick and clumsy
The ETA O2 is stellar.
Under 100, not 1000 ![]()
Only idea I have would be the 1more Triple. It says over ear but it is closer to be On-ear. Tiny bit above the budget though.
A second hand / discounted Sennheiser HD25 maybe
