One handed life hack
yep… i hate having to use both hands to plug or unplug my headphones, gear nowadays is super light. my solution? a 1.5lb weight.
works awesome. plug headphones in/out with one hand all day long. gives your free hand room for activities.
bonus tip:
if you believe it does, it also cuts down on case vibrations and lowers noise. put a high resolution sticker on the weight though…or else this won’t work
Or get a heavier Amp :stuck_out_tongue:
Zeos hack = bluetack.
Or just -> 3M VHB duoble side tape.
“One handed life hack” use the left hand. Giggidy
This is super cheap stuff you can buy in the kitchen section of Target or Wal-Mart. It’s foam rubber stuff meant to put under your silverwear organizer so it doesn’t slide around your kitchen drawer. It’s doing a good job of keeping my gear from sliding around the desktop when I plug/unplug cans and push buttons. I’ve cut a notch out of this chunk to stick under my Asgard.
My desktop is covered in that. Kinda looks good too.
Then you might aswell go for industrial anti-slip mats:
Or you could use a spare 24 inch monitor to hold it still..
If you cut your wires off technically it becomes wireless
im glad you all have a free hand to do with what you wish
