This is the official thread for the OPAL Audio AM7
- Type: Over Ear
- Amp needed: ??
- Open Back
Looks nice for $431.
I’ve been using them for a while now. The build quality is excellent, and they look great too. They’re really comfortable to wear.
The clamp force is definitely strong at the beginning, but after wearing them for a while, it starts to go away. It’s something you get used to pretty quickly.
I’ve actually been using these over my Moondrop Para and HD600, and I’ve been loving them ever since. They’ve become my go-to.
The only gripe I have is with the cable. Most people won’t have a 3.5mm TRS cable, and if you have an expensive TS cable like the Magia cable, it won’t work—which is a bit of a downside.(stock sable is good but if you have a balanced setup you would need to order one because you get 3.5mm to double
3.5 TRS cable)
Overall, I’d still recommend them, can’t wait with what Opal will come up next ![]()
