can this cable adapt to a e-mu teak headphone thank you
If you have the dual-entry removable cable Teaks, I think theyâre 2.5mm which Open Heart makes. I did a removable cable mod on my Grados with dual mono 2.5mm and the Open Hearts work well with them. Impossibly low price for the design/fit-finish. I have dual 3.5mm cable and it is great too.
They do look like nice cables. Iâll keep those in mind in the future.
Damn, I wish I knew that like two weeks ago! 'course, these will likely not be my last Hart cables, so itâs not a big deal either.
be sure you donât mix Hart cables with Open Heart cables⌠![]()
Just bought the same cable for my incoming Zeus, however, they didnât have a 1/4" / 6.35mm plug⌠anyone have any luck sourcing a matching 3.5mm to 6.35mm adaptor?
I decided to try these out, just because they do look pretty nice. Iâm having them make a silver cable for my he1000v2. If you ask, theyâll make you whatever you want, but it takes them a little bit. Iâll update once I actually have it paid for an on its way.
hello is there a site to contact them directly and not by aliexpress?
I communicated through AliExpress. I did not come across another site, but that doesnât mean it doesnât exist.
DD HiFi make a 3.5 female to 1/4" male adapter.
https://www.ddhifi.com/productinfo/977294.html
The problem isnât coverting 3.5mm to 6.35 / 1/4", itâs getting that same beautiful machined brass!
