Yes, the premium has a more comfortable clamp, and also the straight cable instead of the higher clamp and coiled cable on the pro.
Also make sure to not get the black edition ones as they are brighter
ok, thanks guys
Also for the liquid spark you might need to pick up a pair of rca cables to connect the syba sonic to the liquid spark if you don’t have any rca cables lying around
880 600 ohm is my pick. The 600 ohm is going to be better than the 250 ohm even. It just needs a little more power. But it would be worth it for the upgrade.
