I have these Edifier R1850DB connected to a Monoprice 60-Watt Powered Subwoofer - 8 Inch via the sub out. The Edifiers are connected to a Creative X3 via optical and my question is, what is the max bit/HZ I can send the speakers? The X3 is rated at Playback Resolution (Optical Out): PCM 16/24-bit / 48.0, 96.0, 192.0 kHz and the Edifiers state in the manual that only PCM signals with 44.1/48hz can be decoded via optical in. Does that mean the max I can send it is 24bit 48HZ via optical?
Man last time I tried 384khz on a 192 DAC I got transported to an alien world back in 1246 bc and boy did it take me a while tog et back! Gotta be really careful.
Nah seriously. Depends on the DAC; some won’t play, some will sound odd, other’s can downsample it themselves and play perfectly. Try and see. no fire or space-time continuum usually occurs.
