Overnight Sensation (DIY)
Anyone build these? I just ordered the kit from parts express. Working out what to use as an amp/ dac for them.
I have not built them, but they can not handle a ton of juice. Most small stereo amps should work fine with them.
that is a pretty common amp paired with the Overnights
Thanks, i will check it out…
So I pulled the trigger on a Khadas Tone Board for a DAC and a Micca OriGain Amp to pair up with my Overnight Sensations.
Going to take a few weeks until I receive everything and get the speakers built.
Looking forward to my 1st speaker setup and it being budget and DYI.. :slight_smile:
nice, those should work well. you should be a happy camper =)
Received my kit.. Time to build..
Crossover layouts done, time to solder…
1st one finished
Received my Micca Origain Amp today.
Got my Khadas Tone Board..
Tone Board paired with the Origain… (I have a case coming for the tone board)
Looking good so far, great pics to!
Gluing up..
Nice looking cabs. I have not tried PE cabinets yet, think I will have to! What straps are those? I love them and would be waaay more convenient than clamps for small bookshelves. I been making them for friends and family for a few years now, addicted to building lol =)
They are Powertec Deluxe Band Clamps, bought them on Amazon.
last night I tried to test my crossovers to make sure they were working correctly before I mounted them inside the cabs and glued the front face on. my test was a fail…
Today I found a different passive speaker to test my DAC-AMP-SPEAKER WIRE path as good. Turns out the problem was the Micca pre-made speaker cables I bought. The crossovers are good to go…
Interesting that the cables turned out to be the issue, well that’s good that your crossovers are good
Another step complete.. Time to put the face panel on..
