Overwhelm by so many new choices - Best IEMs under 200
Hello everyone!
I just came back to the hobby after a year or so of inactivity. I wanted to get some IEMs, mostly for home, thinking the choice would be easy but there are so many new IEMs that I am overwhelm now.
For budget I was thinking 200 euros. Could be stretched if the improvements are clear (as always).
I wouldn’t focus so much on the sound signature or sound preference right now as I am planning on getting 2 or 3 IEMs to have a complete variety of sounds to chose from depending on what I feel like listening on that specific moment.
I see that right now there are a couple of names that are floating everywhere like the 7hz timeless, mangrid TEA, Tripowin Olina, Moondrop Kato, Shuoer S12 or Z12, Yume midnight… I was wondering how do these new boys (at least to me) compare to the recommendations that I remember were instatly recommended for this budget. I’m talking about sets like: Ikko OH10, Tape pro, Legacy 3, Fiio FH5, Tin P1, Starfields… For sure there are some more than I am missing. I would like to know if the starfields and the OH10 have been dethrone or became irrelevant due to some new players that do the same but better.
As I said in terms of sound signature I’m not looking for anything specific right now, I would like to have 2 or 3 sets that complement each other, right now I’m looking for the best quality for the money. There is actually one kind of profile I would like to have and that is something very intimate, that brings out the voices to the front and has a clear imaging and separation (not sure if there is something like this).
If you guys can suggest a good 3 piece combo of IEMs would be great, something like a natural sounding detail iem, a warm relaxed sound signature and a intimate vocal focused piece. Something along those lines.
I would run them of an IFI Zen Dac V2, probably would get the FIO btr7 in the future for convenience.
Thank you in advance for your suggestions and help!
I love the original Mangird Tea, but they are over the 200 price point. You can find them on sale around $240 at points.
My favorite under 200, or 100, is the Olina, which I run with double stock filters. If you want great stage and imaging, I find the Olina to be fantastic at both. I am curious to see if the new Special Edition version is on par with it for imaging.
My pick after those is the S12. I own the Timeless, and listen to the S12 more.
I typically use the BTR5 as my DAC/Amp with all of those.
The OH10 is still a good IEM, but I don’t like the weight, and they are a bit too V-shaped for my tastes. The Starfields are still good, but I would take the Olina over them today.
I think you could do:
Olina SE - Natural, detailed IEM (OG Olina if you want more upper-mid energy)
Tri x HBB Kai - warm, relaxed
7Hz Zero/Moondrop Chu - Vocal focused
Three sets, on your budget, hitting each of your targets? In terms of safe, well respected recommendations, I think you could be done here.
My personal recommendation, if you want 1 set and the option to hit all of your requirements: Tri Starsea. You can have all your flavors of ice cream in one set.
Thank you for your input!
Looks like the Olina is a sure purchase overwhelmingly positive reviews.
Mangrid Tea is also very appealing to me but for a reason that I can’t even explain, just feels like a good purchase.
I have the same concerns about the OH10, everyone says is really heavy and usually I have a hard time with IEMs staying in place and the weight extra weight will not help.
Is this Olina SE out already? I didn’t even know there was such a version. I also did not know this Tri starsea, I will look for more info on this set. what is a short description of this starsea?
Starsea is a 1DD + 2BA hybrid set, with tuning switches that actually affect the frequency response.
It’s standard setting is the most balanced setting, with the best soundstage and musicality to my ear
It has a bass setting, that only slightly elevates the bass and makes it a little more V-shaped.
It’s balanced setting is the most neutral setting. It lowers the bass and levels the treble, while making the mids more present. It has the most intimate soundstage of the four. This would be your “details” setting.
The vocal setting raises the upper-mids to emphasize vocals more. It’s the brightest setting.
I think standard, balanced, vocal would check all your boxes
If you want two iems for $200 then I would recommend the Dunu Titan S and Fiio FH3 but if you just want one at or under your budget I would get the S12 or Z12 if you want a little more subbass.
Yes, it’s already available at Linsoul website or DD-Audio Store (Linsoul’s store on AliExpress).
I have Olina OG and Shuoer S12 and recommend both.
But for Olina, get the SE version that according to HBB it’s an improved Olina OG.
Mangird Tea is highly appreciated and recommended by members here for it unique tuning.
I got Mangird Tea 2 but is still on route.
Look at the HighSenior Mega 5P
Still wish I knew more about these than just Tony’s review.
If you can stretch your budget then grab the Mangird Tea ($260 USD) and Salnotes Zero ($15 USD); wait for sale. Both gives you different sound signatures (don’t be fooled by Zero’s pricing).
If you can’t stretch the budget then grab the Olina SE ($100) and Truthears x Crin Zero ($20?); Olina is neutral-bright where the Truthears is sub-bass focused. I’m personally not a fan of planar IEMs like the S12 and Timeless; note-weight is too light, thin sounding, soundstage is off/lacks width, and treble has bad dynamics and is too bright and uneven.
I agreed with every one of Tony’s ears/reviews for the ones I listened to so thought it would be a safe recommendation. Thou I haven’t heard them personally.J
Mangird Tea is discontinued. RIP.
Under 200:
Like the olina for vocals and a bit of air, and timeless for my metal fix but have fitment problems with them :confused: did just buy some z12 in hope of better fitment for nearly the same sound :sweat_smile:
Wait, what ? That makes me sad.
I am sure the Tea MKII is great too, but the tuning isn’t as distinct.
Also I agree with @DuerumBen about Timeless for metalheads. I tend to get them out when I am listening to Iron Maiden or Metallica. The S12 is a bit too bright for metal.
Mangird Tea still available on Taobao under Xenns’s store it seems. But you’ll need to be in one of the SAR or Mainland to login I think? But I might be wrong.
On the same page… Is there right now something similar to the Blon bl 03 sound signature (decent technicalities, soundstage and instrument separation, with nice bass boost for electronic músic, smooth treble for long listening time and natural timbre on voices and instruments) on the 200$ range?
Oh10. Sub bass, good bass, clean mids, good highs. Imaging best i have heard and very good soundstage.
I change the stock cable and looks good.
For me more enjoyable than Timeless. A little better than S12 (its similar in tech but better for soundtracks due to having more soundtage “holographic”. Similar clarity, imaging better in Oh10, resolution a little better in s12), better than Spring 2, better than Olina, better than Tea in multiple genres.
Is the weight of the OH10 something to be worried about? Is it annoying or hard to keep in them in place? I can get them in amazon local for 160€ with prime delivery. In Aliexpress for whatever reason is more expensive, 225.€
If it’s on Amazon, buy it. Normally it is a little more expensive than Aliexpress but it is cheaper without hesitation.
In case you don’t like it, you can return it.
If you buy it I would like to know your opinion. I always like to learn and listen to other people’s opinions.
The Dan audio channel has demos. They can help you choose.
