Pad swap for the Coolermaster 751?
Hi has anyone tried pad swapping the MH 751? thinking of playing around with mine and interested if anyone has tried.
I’m thinking that maybe something like a brainwave angled PU pad might work but I’m also not 100% sure about the compatibility
I’d email them to see what they recommend size wise or you could rip off the pads and take measurements. A lot of pads have fabric you can stretch over the cups (and you can always add tape or blu tac for a better seal). Looking at the measurements of the MH751, might want to consider sheepskin pads though to tame the murderous treble spike. Good luck!
