Personally I would swap the bifrost 2 and su8, so you feed the higher quality amp a better dac, and give the jot a bit more analytical signal from the su8 so it doesn’t get as muddled, but that’s just me
I don’t think the Fulla 2 really needs an amp unless it’s driving something a bit harder to drive. The JDS Labs and Fulla 2 are both op amp based so the sound signatures should be practically identical. I wouldn’t include an additional amp unless you’re driving some hard drive headphones.
Right, I’m just saying the only difference between a Fulla 2 and a Fulla 2 with an Atom is the cable. If I were to use the Fulla 2 as a dac only, I’d connect it to an amp that has a touch of coloring to hear any difference out of the Fulla 2 directly.
That should work. Also, Jason Stoddard of Schiit wrote a post on blind testing… he personally hear a difference from the Vali 2 and the Schiit Heresy. So… the stock tube apparently sounds the same as the latest clean budget amp which also sounds like a more powerful Fulla. But… Vali + Fulla 2 does sound like a much better pairing.
