While pugging a pixel 6a to a Topping D30 pro dac using a generic usb c - usb converter there was a crack/pop and DAC stopped receiving audio signal from usb.
Switched to a pc, replug power didnt fix the issue, but replug the usb connector fixed it.
DAC works now but cant tell if it is damaged. Should I get a replacement?
Looked it up and this is a known issue with the pixel phones.
