Hello, fellow headphone lovers!
I am reaching out regarding my search for new headphones. While I am getting ready to visit Munich 2023 Hi-Fi expo, I would like to make sure I do not miss any brand/model you think might fit my needs.
Let me open by going over headphones I previously owned:
Creative Aurvana Live! AKA CAL1 ![]()
These are the ones that were sporting the same Foster 40mm “biodynamic” driver used in way more expensive Denon headphones. I loved the, and I killed a bunch of them. The main flaw was the poor build and non-removable cables which I tried to address with DIA 2,5mm ports I installed in each ear cup but ended up killing that pair as well.
[MEDIA=youtube]5DfFYXBYYcA[/MEDIA]
[MEDIA=youtube]hGKj_tAnjwo[/MEDIA]
Sund demo: [MEDIA=youtube]cMOvxo0TFNQ[/MEDIA]
Do you know if this driver is still used in any headphones today? I would buy it just for the nostalgia reference.
Sennheiser Momentum In-Ear (Android version)
The sound was ok, a bit bassy, the cable could have been better, took me a while to dind the right tips to fit in my ear.
Meze 99 Classics ![]()
Great sound, easy to drive, good removable cables,… I took them everywhere with me and lost them under tragic circumstances.
It still hurts.
[MEDIA=youtube]hEid0p0Vgwo[/MEDIA]
O2/Odac Combo ![]()
https://mayflowerelectronics.com/o2-odac-overview/
[MEDIA=youtube]7MNDhLmoOX4[/MEDIA]
And at work - Sennheiser PC 8 USB
I tried Drop Sennheiser HD 6xx
. I liked the sound, but they are open and I rarely enjoy music in a completely silent environment. Also, I felt like these would benefit from the sound is a bit more colored, perhaps by using a tube amp!?
I also tested Sennheiser HD 800
- I did not like their sound. I am one of the people sensitive to pronounced highs and I do not like my ears bleeding when listening to music. Maybe something I could fix via EQ but I would prefer headphones I can enjoy without doing that.
I own a new Samsung Galaxy S23 Ultra with 512 GB storage so hope to use that as my FLAC storage/player on the go.
At home it comes to iPad to play streamed music, FLAC (from NAS), and movies.
Neither has a headphone port anymore.
So what’s the plan?
- New closed, around-the-ear headphones, budget ideally under 500$ {900$ including any possible extra gear, new portable DACAMP, pads, cables).
- Ideally, easy to drive*
*I could get something harder to drive but that would require DACAMP on he go, attached to my phone (BTR7?)
- A sound signature like Meze 99 Classics. I was quite happy with the sound across different styles of music.
- I haven’t tried balanced sound. That would be something to test out and perhaps switch to going forward…
Can you share your recommendations and what brands/models I should listen to while I attend the HIGH END Munich 2023 next month?
Thank you!
Jiri
